Visual Land Prestige 10 Battery Replacement
  1. Visual Land Prestige 10 Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Visual Land Prestige 10 Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Visual Land Prestige 10 Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Visual Land Prestige 10 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Visual Land Prestige 10 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Visual Land Prestige 10 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. Visual Land Prestige 10 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Visual Land Prestige 10 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Visual Land Prestige 10 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • now that the case is open, carefully remove the speakers and set aside.
  4. Visual Land Prestige 10 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Visual Land Prestige 10 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the speakers from the back case with tweezers and set the case aside.
  5. Visual Land Prestige 10 Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Visual Land Prestige 10 Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Visual Land Prestige 10 Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove yellow tape from surrounding components.
  6. Visual Land Prestige 10 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Visual Land Prestige 10 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Visual Land Prestige 10 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • insert the spudger and gently work around and underneath the battery.
    • With the battery separated from the LCD Display, set it aside.
    • The battery is held down by very strong adhesive.
  7. Visual Land Prestige 10 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder and remove the 2 wires from the motherboard.
    • Use caution when desoldering to avoid damage to yourself or to the components.
    go to Amazon and order a Prestige Prime 10SE tablet
    Ashy Sparman -
    go to Amazon and order an Prestige Prime 10SE tablet
    Ashy Sparman -
    your tutorial worked but my tablet is a little different but it has the same model id
    Ashy Sparman - crwdns2934203:0crwdne2934203:0
crwdns2935229:08crwdne2935229:0
Connor Reese
crwdns2935283:004/08/15crwdne2935283:0
1.298 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 2-1, Matresse Spring 2015 crwdns2935289:0Eastern Washington University, Team 2-1, Matresse Spring 2015crwdne2935289:0
EWU-MATRESSE-S15S2G1
crwdns2947412:07crwdne2947412:0
Wat if the charge port how do u replace it Visaul land 10.1
jessiepettway - crwdns2934203:0crwdne2934203:0
Thank you for posting. Great illustrations. Got mine apart so easy.
Lori Pepper - crwdns2934203:0crwdne2934203:0
where can I get a replacement battery for Visual Land Prestige 10D tablet?
John Conger - crwdns2934203:0crwdne2934203:0
Where can I get a replacement battery for Visual Land Prestige 10.1 tablet???
Thank you.
Belinda Rivera
brp52@hotmail.com
Belinda Lorenzana - crwdns2934203:0crwdne2934203:0
where can I get a replacement battery for visionland prestige 10 3.7v
Fred Maxwell - crwdns2934203:0crwdne2934203:0
Where can i get a replacement battery for my prestige elite 10 Q?
Colton - crwdns2934203:0crwdne2934203:0
My power button is not working at all, seems to be stuck/pushed in. How do I fix this? Only way for me to turn it on is to connect it to the charger cord.
dawn bratcher - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 8,358
