Use this guide to remove the glass in the scanner bed in order to replace it.
On the bottom of the scanner, remove the screw at the top left side.
Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
Remove the screw beneath the foot-pad.
Rotate the scanner so the screw hole is located on the top left hand side.
Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
Gently pry the two casements apart beginning above the screw hole and working your way around.
Apply even pressure against the back of the glass while securing the plastic frame in place.
With consistent pressure on the glass, move your fingers down the sides until the glass is no longer stuck to the double-sided tape.
