This guide is intended to help users through the process of fixing broken or worn out violin strings. A violin has four strings: E, A, D, & G. The order of the strings from left to right is G, D, A, & E. The G string is the deepest pitched string and the E is the highest pitched string. The purpose of this guide is to enable violin players to restring their violin on their own instead of having it done at a music store.
Turn the peg belonging to the string you are wanting to change to loosen the string.
Remove the opposite end of the string from the fine tuner holder.
Make sure the string is sitting in the groove in the bridge.
Gently tug on string to make sure it is secure.
crwdns2935229:05crwdne2935229:0
Thanks for this very clear set of instructions with clear images. I am an amateur violinist and broke a string while tuning. Even I could use these instructions and it was as easy as the post says. Thanks for posting and to ifixit in general.
Svasangana jeevi - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
