This repair guide is for the Vintage Mini Vornado fan. After extended use, the blade on Vintage Mini Vornado fans can wear down and fail to produce a strong air flow. This guide demonstrates how to properly maintain and replace the blade. It is important that the fan is unplugged before starting the repair to avoid any accidents.
Prop the cap out of each hole with a pry tool to remove the blade cap.
Face the front of the fan and pull the blade directly towards you to loosen it.
Pull the blade out of the rod.
If you have purchased a new blade, make sure the orientation matches the one you just removed.
Use a cloth to dust the blade or other interior areas of the fan.
Place the blade back inside of the fan.
Place the blade cap on and secure it into the three holes.
Use a pry tool with a cloth to help apply pressure and push the cap into place.
