Video Guide: Rancilio Silvia Grouphead Screen & Gasket Replacment
    • How to Identify which Silvia version you have.
    • Remove Water tank, drip tray and portafilter.
    • Flip the machine upside down.
    • Remove screen screw with flat head screwdriver.
    • Remove the old screen.
    • Remove and soak diffuser in Joe Glo coffee cleaner.
    • On version 3 you will need to remove and soak the brass disc as well.
    • Pry the gasket up with the sharp tip of the awl.
    • Use Joe Glo coffee cleaner and hot water to soak the grouphead for 10-15 minutes.
    • With a wire brush, clean the top of the grouphead.
    • Use a paper towel / regular towel to soak the dirty water from the grouphead.
    • Use the compressed air can to clean any excess water or coffee.
    • Last but not least, use the pick on the top and bottom rails to remove last bits of coffee debris.
    • Take the new gasket and install it with the lettering down.
    • Use a 1/4 inch flat punch to push down the gasket to ensure its nice and flat.
    • Insert the diffuser with the water channels facing down.
    • Place the new screen and insert the screw.
    • Use an 8mm socket wrench to tighten the screw.
    • Congratulations! You fixed the machine!
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0636crwdne2935297:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 2,365
