Viasys Avea Battery Replacement
  1. Viasys Avea Battery Replacement, Viasys Avea UIM and Plastic Cover Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ‘rubber collar’ located at the UIM rear neck, by grasping one of the two rubber tabs at the bottom. Pull firmly in an “arcing” motion.
    • Pull UIM forward and look for the Phillips Screw on the front arm cover. Remove (1) Phillips screw from the front arm cover. Remove the front arm cover.
    • Remove the two mounting screws now visible inside the ‘back arm cover’. Tilt the UIM down and remove the ‘back arm cover’.
  2. Viasys Avea Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the (4) 11/32 KEP nuts that secure the ‘plastic top cover’ opening onto the chassis.
    • Remove (2) Phillips screws that secure the ‘plastic top cover’ to the rear chassis.
    • Slide the top ‘plastic top cover’ upward and forward away from the chassis.
    • Remove the (2) Phillips screws and washers that secure the HSSC Cable on the GDE. Unplug the HSSC Cable.
    • Carefully feed the HSSC Cable through the ‘plastic top cover’ opening.
    • While continuously supporting the UIM, remove (4) 3/8 nuts that fasten the UIM support arm onto the pneumatics.
    • Lift UIM off of pneumatics and set aside.
    • Remove plastic cover and set aside.
    • Check to see if the exhalation filter assembly is installed, if it is, remove the exhalation filter assembly.
    • Rotate the metal locking lever on the lower right of the ventilator body forward to an open position.
    • Remove the exhalation filter assembly from the ventilator body by pulling straight down.
    • Using a long Phillips screwdriver, remove the Phillips screw located at the top of the exhalation filter assembly well, if applicable.
    • Using a long Phillips screwdriver, remove the Phillips screw located at the exhalation port marked EXH, if applicable.
    • Using a long Phillips screwdriver, remove the Phillips screw from the outside of the plastic cover.
    • Using a long Phillips screwdriver, remove the Phillips screw on the font left wall.
    • Using a long Phillips screwdriver, remove the Phillips screw on the right side of the wall.
    • Set the plastic cover aside.
    • Using a long Phillips screwdriver, remove the 3 Phillips screws on the metal re-enforcement cover, if applicable, and set aside.
    • Remove the Exhalation Corner Assembly.
    • Locate metal top cover
    • Remove the 19 SEMS screws, (3) on the left side (5) on the right sife and (11) on top.
    • Remove metal top cover and set aside.
    • Disconnect the internal battery 2 pin Molex connector
  3. Viasys Avea Battery Replacement, Battery: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the internal batteries
    • Disconnect the battery fuse holder by pulling straight back on the two faston connectors.
    • Remove the fuse holder and fuse from the ventilator chassis using pliers to remove nut.
    • Remove the (3) 11/32 KEPS nuts that hold the battery bracket in place; (2) KEPS nuts on the bottom and (1) on the top.
    • Slide out the retaining bracket and the batteries.
    • Disconnect the positive and negative leads from the wire harness that connects to the driver transition board.
    • Cut both tie wraps that secure the battery monitor board and the 4-pin molex to the batteries.
    • Disconnect the batteries from each other.
Anthony Hernandez
crwdns2935283:005/04/20crwdne2935283:0
394 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G1, Zimmerman Spring 2020 crwdns2935289:0Cal Poly, Team S1-G1, Zimmerman Spring 2020crwdne2935289:0
CPSU-ZIMMERMAN-S20S1G1
crwdns2942667:0crwdne2942667:0 510
