Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement
  1. Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement, Plastic Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement, Plastic Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement, Plastic Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the SIM card, that is located on top of the Jetpack.
  2. Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Phillips #00 Screwdriver
    $5.49
    • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
    • Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
    • You may need to peel back a piece of double sided tape covering the screw hole.
  3. Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 1.25 mm screws.
  4. Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    iFixit Opening Picks (Set of 6)
  5. Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the cover is off, this is what your device will look like.
Richard J Porras
crwdns2935283:001/23/16crwdne2935283:0
504 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-3, Baechle Spring 2016 crwdns2935289:0IUPUI, Team 3-3, Baechle Spring 2016crwdne2935289:0
IUPUI-BAECHLE-S16S3G3
crwdns2942667:0crwdne2942667:0 615
