Verizon Ellipsis 10 Motherboard Replacement
  1. Verizon Ellipsis 10 Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 Motherboard Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
  6. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top piece of tape using an iFixit opening tool.
  7. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
  8. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
  9. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
  10. Verizon Ellipsis 10 Motherboard Replacement, Camera: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 4 M1.5 screws holding in the labeled LTE module.
  11. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a nylon spudger to pry up the module.
    • It's held in with some clips so there will be a little bit of resistance.
  12. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 M1.5 screws holding in the labeled auxiliary LTE/GPS module.
    • The module should come up with a little resistance.
  13. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to lift up the front camera off its locating post.
  14. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the non-conductive tape covering the camera ribbon cable.
    • You may need to remove the white antenna cable to remove the tape.
  15. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully unplug the ribbon cable from the motherboard.
  16. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel up the ribbon cable carefully as it is glued to the device.
    • After having peeled up the cable, the cameras should be free to come out of the device.
  17. Verizon Ellipsis 10 Motherboard Replacement, Motherboard: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the non-conductive tape covering two ribbon cables.
  18. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently unplug both the orange and white ribbon cables.
  19. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to pry/disconnect both the black and white antenna cables from the top of the motherboard.
  20. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the last ribbon cable from the bottom of the motherboard.
  21. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all M1.5 screws holding in the motherboard.
  22. Verizon Ellipsis 10 Motherboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all screws are removed, the motherboard should easily come off the device without any resistance.
Marco Bellutta
crwdns2935283:004/05/19crwdne2935283:0
253 crwdns2915208:0crwdne2915208:0
Oregon Institute of Technology, Team S2-G10, Lancaster Spring 2019 crwdns2935289:0Oregon Institute of Technology, Team S2-G10, Lancaster Spring 2019crwdne2935289:0
OIT-LANCASTER-S19S2G10
my Verizon se apaga cuando subo el volumen,que sera?
Gabriela Monti - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 418
