Vent/Bleed Coolant System on BMW E60/E90
crwdns2936621:0crwdne2936621:0
    • Insert key in the dash or steering column.
    • With foot OFF the brake (don't want to start the car), push the start button (headlamps and interior systems come on).
    • Turn both temp dials as high as they will go and put the fan on the lowest setting.
    • Push the accelerator pedal in for ten seconds then let go - you will hear the water pump cycle on.
    • Set a timer for 12-15 minutes. In this time period, you will hear the water pump cycle on and off and coolant gurgling at the reservoir.
    • After 12-15 minutes turn the car off, remove the reservoir cap and check the fluid - it should be slightly below where you started.
    • Start your car. Watch your temperature. If the car will run without overheating you're done. If you will notice that the temperature is rising repeat these steps.
lifeoftech
crwdns2935283:011/04/09crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 78
crwdns2936753:030crwdne2936753:0 307
crwdns2942667:0crwdne2942667:0 32,213
