Sounds easy, but you need to modify the new rear mudguard.
The most time consuming step is to buy the mudguards. This sounds easy except
- Vanmoof don't list the mudguards. Email Vanmoof support and they'll create a special sales link. You need to buy the M2/M3 mudguards which can be made to fit.
- They only ship to certain countries (why, it’s just postage?). It took 6 months to pick mine up !!
Make sure you get 2 mudguards, one set of stays that are straight for the rear, and a second that have a bend. Also make sure you have the two rear connection pieces.
You need to cut both sides of the mudguard so it can fit between the chain stays, and drill a new hole to attach to the bottom of the frame.
The rear mudguard will need to be cut at the front.
First cut at parallel to the bottom about 16mm long
Second cut is 7mm in from the rounded edge
Bend the edges over so you make a rounded lip
Drill the frame attachment hole
