VanMoof No 3 - Upgrade to 8-speed gear
  1. VanMoof No 3 -  Upgrade to 8-speed gear, What you'll need: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shimano SG-C6001-8C Nexus 8. This is the one with the coaster brake.
    • Chain ring, gear lever, seals, and clips
    • Shimano Grip Shifter Nexus 8-speed Sl-C60008
    • Gear cable (inner and outer)
    • Spokes 36 * 284mm stainless steel spokes
  2. VanMoof No 3 -  Upgrade to 8-speed gear, Double check your spoke length: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Measure the inside diameter of your wheel
    • Use this calculator https://leonard.io/edd/
    • Add 2mm. You should get 284mm spokes
    • I brought silver Halo spokes from ebay. They are decent quality and have not rusted.
    • You need to stretch the rear frame dropouts because the 8-speed hub is wider (135mm) than the 3-speed one (110mm)
    • I got my local bike shop to do this because there's a risk for damaging your frame.
    • The cost was $150 AUD
  3. VanMoof No 3 -  Upgrade to 8-speed gear, Replace the spokes: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VanMoof No 3 -  Upgrade to 8-speed gear, Replace the spokes: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all the old spokes from your wheel
    • Spoke the 8 speed gear into the wheel. This is the best guide https://www.youtube.com/watch?v=mIU6mi0K...
    • Tighten all the spokes using a screwdriver. Use the same torque on the screwdriver and check by "plucking" the spokes so they sound the same
    • Turn the bike upside down, install the wheel, and true the wheel. I hold a screwdriver against the frame and slowly spin the wheel. When it moves in, I just tighten the opposite spokes
  4. VanMoof No 3 -  Upgrade to 8-speed gear, Install back wheel and cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the old inner cable out from the front
    • Push the new inner cable into the old outer cable
    • Pull the old outer gear cable out of the back of the bottom of the frame. LEAVE THE INNER CABLE IN so you can use it as a guide through the frame.
    • Push the new outer cable in from the back
  5. VanMoof No 3 -  Upgrade to 8-speed gear, Replace the gear twist: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the handlebar grip. I pushed a spoke between the grip and the bar and rolled the spoke to loosen the grip
    • Install new gear change
    • Replace the handle bar grip. I wiped the handle bar and inside grip with alcohol.
    • Connect the gear cable.
    • Use a spoke to rotate the gear change
Martin Hampton
crwdns2935283:002/13/16crwdne2935283:0
1.308 crwdns2915208:0crwdne2915208:0
Would this be a possible solution for a bike with a broken eshifter? I have an x3 with err44 and cannot find a replacement part.
Jon Stewart - crwdns2934203:0crwdne2934203:0
I've seen a few e-shifters for sale on facebook, and there are guides on how to fix the electronics so I'd probably go that route. The main problem I can think of with changing to the 8 speed is you'll need to deal with e-shifter wire and you'll need to route the gear change cable on frame. Good luck!
Martin Hampton -
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 2,452
