The Valiant Automatic Hot Pot kettle is super easy to disassemble! You may want to disassemble this device to replace a dead wire or to see an example of a simple circuit.
Turn the kettle upside down and unscrew the bolt on the bottom.
Open the plastic base to reveal the wires and heating element.
Unclip the gold brackets attached to the wires from the heating element.
Remove the bottom bolt attached to the metal bracket.
Remove the metal bracket from the screw.
Fully remove the black plastic base from the heating element.
Use a Phillips #0 screwdriver to remove the 1 mm screws on each side connecting the metal bracket to the wires.
Use a Phillips #0 screwdriver to remove the 1 mm screw holding the T bracket together.
Open the bracket and remove the resistor.
1 Plastic base with AC plug and insulated wire with gold clip
1 BR210 FC resistor
1 insulated wire with gold clip
1 Metal bracket
2 Bolts
2 Sharp Phillips head screws (attached the wires to the bracket)
1 Flat-bottomed Phillips head screw (held the bracket together)
1 Kettle body with the heating element (metal plate)
When assembled, the kettle automatically heats when plugged in. The kettle does not stop heating nor does it alert you when the water is boiled.
