VTechCS6719-16 Speaker Replacement
  1. VTechCS6719-16 Speaker Replacement, Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the sliding cover on the back of the phone case.
  2. VTechCS6719-16 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now remove the battery by lifting it and removing the two pin cable.
  3. VTechCS6719-16 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 10mm screws on the back of the phone base.
  4. VTechCS6719-16 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the metal spudger edge along the phone and locate the hooks and latches.
    • Locating each of them apply a light but firm lifting force to release the front and back case.
  5. VTechCS6719-16 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The front case should now be freed.
    • Put the front case aside for later.
  6. VTechCS6719-16 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are two 10mm screws located at the top of the circuit board.
    • Unscrewing the screws allows for access to the speaker.
  7. VTechCS6719-16 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flipping the circuit board will expose the speaker rested in the white LCD base.
    • Gently using the scoop end of the spudger will free the speaker from the dock.
    • Careful not to jerk the speaker as it is still attached to the board.
  8. VTechCS6719-16 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The last portion of this will require soldering skills. Simply solder the speaker from the board and replace with desired speaker.
    • If this is your first time soldering, check out this useful soldering guide.
Charles montes
crwdns2935283:010/20/16crwdne2935283:0
513 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-5, Martin Fall 2016 crwdns2935289:0UMass Dartmouth, Team 5-5, Martin Fall 2016crwdne2935289:0
UMASSD-MARTIN-F16S5G5
crwdns2942667:0crwdne2942667:0 300
