crwdns2959928:0crwdne2959928:0 ↓This guide demonstrates a walk-through of steps needed to completely dismantle the phone in order to locate the speaker and replace it with a new one.
Remove the sliding cover on the back of the phone case.
Now remove the battery by lifting it and removing the two pin cable.
Unscrew the two 10mm screws on the back of the phone base.
Locating each of them apply a light but firm lifting force to release the front and back case.
There are two 10mm screws located at the top of the circuit board.
Gently using the scoop end of the spudger will free the speaker from the dock.
The last portion of this will require soldering skills. Simply solder the speaker from the board and replace with desired speaker.
If this is your first time soldering, check out this useful soldering guide.
