crwdns2959928:0crwdne2959928:0 ↓This guide demonstrates a walk-through of steps needed to completely dismantle the phone in order to locate the screen cover and replace it with a new one.
Slide the back cover off the cause.
Lift the battery.
Unplug the two pin cable from the connector.
Unscrew the two 10mm screws in phone base.
When you feel a hook or latch use a firm but gentle lifting motion upward to unlatch the front and back case.
Unscrew a second set of 10mm screws to access to the other side.
Using a single finger apply a light force on the screen cover to release from the case.
Now the old screen can be replaced with a new desired one, simply properly align and it will clip into place.
