This guide demonstrates a walkthrough of steps needed to completely remove the old ringer and put in a nice working new ringer.
Remove sliding back cover from case.
Lift the battery and unplug the two pin cable from phone base.
Slide back cover off the phone
Located at the bottom of the frame are the two-10 mm screws.
Use a Phillips head screwdriver to remove both 10 mm screws.
Using the spudger lift the latch over the ringer to release it.
The last component of the latch is soldered to the circuit board. This will take some soldering expertise.
