crwdns2959928:0crwdne2959928:0 ↓This guide demonstrates a walk-through of steps needed to completely dismantle the phone in order to locate the buttons and replace them with new ones.
Remove the sliding back cover from case.
lift the battery and unplug the two pin cable from phone base.
Remove the two 10mm screws at the base of the phone .
Unscrew a second set of 10mm screws to obtain access to the other side.
You will notice the button covers, these display the numerical values and positions of each button
These can be placed aside as they will get in the way later.
These can easily be removed by pulling away the pads from the circuit board.
To replace simply align the new pad onto the button positions.
