VTech VM3254 Battery Replacement
  1. VTech VM3254 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech VM3254 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
  2. VTech VM3254 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech VM3254 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech VM3254 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the iFixit Jimmy tool to begin removing the face of the monitor.
    • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
    • Once the screen has been separated, lift it from the case.
    • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
  3. VTech VM3254 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech VM3254 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
    • Remove the bracket.
  4. VTech VM3254 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech VM3254 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech VM3254 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the battery from its location.
    • Carefully disconnect the bundled cable connector from the circuit board.
    Wo finde ich denn genau solch eine Batterie ?
    Besten Gruß
    René
    kroenung1990@googlemail.com
    René Krönung - crwdns2934203:0crwdne2934203:0
Jackson Meacham
crwdns2935283:002/14/23crwdne2935283:0
109 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-2, McMurrin Spring 2023 crwdns2935289:0Utah Tech University, Team 1-2, McMurrin Spring 2023crwdne2935289:0
UTAHTECH-MCMURRIN-S23S1G2
What is the battery that needs to be replaced called?
Aden Brooks - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,101
