Is your "TALK" button not working properly? Read this repair guide to learn how to replace it.
Remove the battery cover.
Unplug the battery from its connector and remove.
Using the Phillips #00 screwdriver, unscrew the two 5.0 mm screws at the bottom of the monitor.
Separate the back half of the device from the front using the metal spudger.
Remove the “TALK” button to get access to remove the motherboard.
