crwdns2959928:0crwdne2959928:0 ↓This guide show users how they can replace the buttons of the device.
Remove the battery covers and the four batteries.
Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
Remove the eight 6.0 mm JIS #0 case screws.
Using a plastic opening tool, separate the two pieces of the case carefully.
Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
Remove the three "L" shaped brackets and the spring.
Flip the device over and remove the three 4.0 mm Philips J0 case screws.
Separate the front and back of the case.
Remove 6 (3.8 mm Philips J0) screws holding the buttons in.
From here you can remove and replace the buttons.
