VTech Learning Tunes Karaoke Speaker Replacement
  1. VTech Learning Tunes Karaoke Speaker  Replacement, Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the battery door, loosen the screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Speaker  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech Learning Tunes Karaoke Speaker  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Speaker  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Speaker  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech Learning Tunes Karaoke Speaker  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Carefully place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Speaker  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech Learning Tunes Karaoke Speaker  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 7.9 mm Phillips #1 screws on the speaker cover.
    • After removing the screws, remove the black plastic speaker cover to expose the speaker.
  6. VTech Learning Tunes Karaoke Speaker  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the speaker at the solder points to remove.
    • Learn more about soldering and desoldering connections here.
Gamuchirai Chifamba
crwdns2935283:002/09/16crwdne2935283:0
249 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 7-2, Cheng Spring 2016 crwdns2935289:0USF Tampa, Team 7-2, Cheng Spring 2016crwdne2935289:0
USFT-CHENG-S16S7G2
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 856
