VTech Learning Tunes Karaoke Mode Selector Replacement
  1. VTech Learning Tunes Karaoke Mode Selector Replacement, Mode Selector: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the battery door, loosen the 4mm Flathead screw.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Mode Selector Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech Learning Tunes Karaoke Mode Selector Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Mode Selector Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Mode Selector Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech Learning Tunes Karaoke Mode Selector Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Mode Selector Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 7.9 mm Phillips #1 mode switch board screws.
  6. VTech Learning Tunes Karaoke Mode Selector Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech Learning Tunes Karaoke Mode Selector Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screws have been removed, carefully move the mode switch board to expose the mode switch assembly underneath.
  7. VTech Learning Tunes Karaoke Mode Selector Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech Learning Tunes Karaoke Mode Selector Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Philips #1 screwdriver, remove the two 5.6 mm screws on the switch.
    • Once the screws have been removed, you can easily remove the mode switch.
Adam Chaberek
crwdns2935283:002/09/16crwdne2935283:0
137 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 7-2, Cheng Spring 2016 crwdns2935289:0USF Tampa, Team 7-2, Cheng Spring 2016crwdne2935289:0
USFT-CHENG-S16S7G2
crwdns2942667:0crwdne2942667:0 374
