If the faceplate to your watch is cracked or simply needs a clean, the following guide will show how to remove and replace this piece.
In order to remove the faceplate you must start by placing the watch screen upwards.
Use iFixit’s opening tool, another similar tool, or simply use your fingernail to gently pry open the faceplate away from the screen starting from an edge.
Once successful, pull the remaining faceplate off from the watch.
Where can I find a faceplate?
Where can you buy a replacement face plate?
This doesn't remove the faceplate, just the decorative bezel around the screen. I'm looking for disassembly instructions to open up the screen as my son wore his I to the pool (immediately after being told not to! Kids…)
Where can I get a replacement faceplate please
