VTech Kidizoom Smartwatch DX2 Battery Replacement
  1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech Kidizoom Smartwatch DX2 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech Kidizoom Smartwatch DX2 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech Kidizoom Smartwatch DX2 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech Kidizoom Smartwatch DX2 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Battery Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech Kidizoom Smartwatch DX2 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech Kidizoom Smartwatch DX2 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry the battery off of the circuit board using the plastic opening tool.
  9. VTech Kidizoom Smartwatch DX2 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • De-solder the wires connecting the battery to the circuit board.
    • Remove the battery.
Jessica Richard
crwdns2935283:010/25/18crwdne2935283:0
515 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G5, Peak Fall 2018 crwdns2935289:0UMass Dartmouth, Team S3-G5, Peak Fall 2018crwdne2935289:0
UMASSD-PEAK-F18S3G5
crwdns2947412:05crwdne2947412:0
Hey guys, My VTech watch is plugged in but once I turn it on it does but then shows a dead battery. I actually didn’t play with it for a while and I left it dead battery.
Gabriel Baker - crwdns2934203:0crwdne2934203:0
So I might try this trick and see if it works.
Can I cut the wires connected?
TECH DUDE - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 81
crwdns2942667:0crwdne2942667:0 10,859
