Exercise caution when soldering the speaker to and from the motherboard, as you could possibly melt the motherboard. This replacement is one of the most difficult, as it requires expertise with a soldering iron and a steady hand.
            Using a plastic opening tool, gently pry off the circular plating over the camera lens.
   crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95-
            Use a #0 screwdriver to remove the two 2.5mm Phillips head screws located on the second layer of plating.
            Remove the second layer of plating previously held down by the screws by gripping it with your fingers and pulling upward.
            Pry off the transparent plating and paper design using a plastic opening tool.
            Unscrew the (4) 2.5mm Phillips head screws from the third layer of plating using a #0 screwdriver.
            Turn the camera around and gently remove the plating that surrounds the LCD screen by grasping it with your fingers and pulling away from the device.
            Use the plastic opening tool to lift the LCD screen, including the purple casing and set it aside, revealing the motherboard and connector ribbon.
            Use the soldering iron to reheat the solder around the speakers' prongs on the motherboard.
            Pry the speaker off the motherboard using a plastic opening tool.
HTC one camara
Hi,
Thanks for the video, was very helpful.
could you pls advice where can I get new speaker or spec for orig one.
my boy was able to destroy it…
