This guide will show how to replace the screen in the VTech Innotab Max.
Remove all screw caps from the back panel using a metal spudger.
Next remove all of the now uncovered screws.
Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
Here you can see the back cover has been fully removed and you can now access the front cover.
To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
The battery is now fully disconnected.
In order to unlock the screen you need to remove the 4 pins that can be seen in the picture.
To remove simply just turn and pull them out. Use a metal or nylon spudger if they are too small to grip.
Once the pins are removed the screen should be loose from the frame and only connected by the brown film pictured.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
In order to completely remove the screen you need to unclip the film from the motherboard by simply using a pair of tweezers and gently pulling.
Once unclipped from the motherboard the screen should be entirely free from the device
crwdns2947412:05crwdne2947412:0
Where can I buy a screen
Damien Hennigan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can I buy a screen? Can't find any sites that sell the innotab Max screens.
i can not seem to find a replacement screen online, where can i buy one? Innotab Max from Vtech… HELP please..
fanny_muller - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello, where can i buy a KIDICOM MAX Rose Screen. Our daughter here is broken!.thanks a lot!
hans.depre@gmail.com
Hans Depre - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
bonjour je cherche a raplasser l ecran du kidicom max car le mien ne salume plus pas merci
theobald - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
