VTech InnoTab Max Battery Replacement
crwdns2942287:0crwdne2942287:0This guide will show how to replace the battery in the VTech InnoTab Max.
crwdns2944105:0crwdne2944105:0
Remove all screw caps from the back panel using a metal spudger.
Next remove all of the now uncovered screws.
Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
Here you can see the back cover has been fully removed and you can now access the front cover.
To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
The double sided tape used to hold down the battery is overkill. I actually had to slice through it CAREFULLY in order to release the battery.
Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
The battery is now fully disconnected.
crwdns2947412:010crwdne2947412:0
Thank you for the useful guide!
Which battery (exact specs) can be used as a replacement?
Where can we purchase a replacement battery
Where can we buy a replacement battery
Nice of you to show this, but I can not find that particular battery anywhere. Not even the China website.
Let us know where we can get the battery.
Since it seems like a replacement battery cannot be purchased anywhere, can the battery be bypassed to still use it plugged in? I know it defeats the purpose of a tablet, but it would be nice to still use it. Anyone have suggestions?
I used a replacement battery for a tablet w/a red, black and white bare wire. I cut the wire long with connector attached off the old battery. I spliced them and it now works and charges. Also had to do some trimming and shaving of the compartment with an exacto knife so battery would fit. I am sure if you look on eBay you can find a bare wire black, red and white. I got mine on ebay for rca tab. but it was wrong, RCA only uses Black and red wire.
Does someone know where to buy this battery, or Which battery (exact specs) can be used as a replacement?
Thanks
Bonjour
où puis je trouver cette batterie ?
Merci
Where can I get replacement batteries for innoTab3S
the charger port is broken
