VTech InnoTab Max Battery Replacement
Jacob Schioppo
crwdns2944107:0crwdnd2944107:0Jacob Schioppocrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0March 4, 2024crwdne2944111:0
10 - 20 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
This guide will show how to replace the battery in the VTech InnoTab Max.
crwdns2944105:0crwdne2944105:0
  1. VTech InnoTab Max Battery Replacement, Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech InnoTab Max Battery Replacement, Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech InnoTab Max Battery Replacement, Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all screw caps from the back panel using a metal spudger.
  2. VTech InnoTab Max Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech InnoTab Max Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech InnoTab Max Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next remove all of the now uncovered screws.
    • If there is a cartridge in the device make sure to remove it.
    Don’t forget the 2 screws under the cartridge.
    Kim Sihota - crwdns2934203:0crwdne2934203:0
  3. VTech InnoTab Max Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech InnoTab Max Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
  4. VTech InnoTab Max Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech InnoTab Max Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here you can see the back cover has been fully removed and you can now access the front cover.
    • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
  5. VTech InnoTab Max Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
  6. VTech InnoTab Max Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech InnoTab Max Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech InnoTab Max Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Plastic Cards
    $2.99
    • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
    • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
    • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
    The double sided tape used to hold down the battery is overkill. I actually had to slice through it CAREFULLY in order to release the battery.
  7. VTech InnoTab Max Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech InnoTab Max Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech InnoTab Max Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
  8. VTech InnoTab Max Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is now fully disconnected.
Jacob Schioppo
crwdns2935283:002/15/17crwdne2935283:0
564 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S5-G5, Lacy Spring 2017 crwdns2935289:0USF Tampa, Team S5-G5, Lacy Spring 2017crwdne2935289:0
USFT-LACY-S17S5G5
crwdns2947412:010crwdne2947412:0
Thank you for the useful guide!
Which battery (exact specs) can be used as a replacement?
kermit - crwdns2934203:0crwdne2934203:0
Where can we purchase a replacement battery
Frank Godon - crwdns2934203:0crwdne2934203:0
Where can we buy a replacement battery
Nice of you to show this, but I can not find that particular battery anywhere. Not even the China website.
Let us know where we can get the battery.
Donald Josefczyk - crwdns2934203:0crwdne2934203:0
Since it seems like a replacement battery cannot be purchased anywhere, can the battery be bypassed to still use it plugged in? I know it defeats the purpose of a tablet, but it would be nice to still use it. Anyone have suggestions?
ktmm - crwdns2934203:0crwdne2934203:0
I used a replacement battery for a tablet w/a red, black and white bare wire. I cut the wire long with connector attached off the old battery. I spliced them and it now works and charges. Also had to do some trimming and shaving of the compartment with an exacto knife so battery would fit. I am sure if you look on eBay you can find a bare wire black, red and white. I got mine on ebay for rca tab. but it was wrong, RCA only uses Black and red wire.
Kathleen A Dombrowski - crwdns2934203:0crwdne2934203:0
Does someone know where to buy this battery, or Which battery (exact specs) can be used as a replacement?
Thanks
peltiarn - crwdns2934203:0crwdne2934203:0
Bonjour
où puis je trouver cette batterie ?
Merci
alainparent62 - crwdns2934203:0crwdne2934203:0
Where can I get replacement batteries for innoTab3S
gwendolynheatley59 - crwdns2934203:0crwdne2934203:0
the charger port is broken
ipod56 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 14,790
