crwdns2959928:0crwdne2959928:0 ↓This guide will show how to replace the battery in the VTech InnoTab Max.
Remove all screw caps from the back panel using a metal spudger.
Next remove all of the now uncovered screws.
Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
Here you can see the back cover has been fully removed and you can now access the front cover.
To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
The battery is now fully disconnected.
crwdns2935229:08crwdne2935229:0
crwdns2947412:010crwdne2947412:0
Thank you for the useful guide!
Which battery (exact specs) can be used as a replacement?
kermit - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can we purchase a replacement battery
Frank Godon - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can we buy a replacement battery
Nice of you to show this, but I can not find that particular battery anywhere. Not even the China website.
Let us know where we can get the battery.
Donald Josefczyk - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Since it seems like a replacement battery cannot be purchased anywhere, can the battery be bypassed to still use it plugged in? I know it defeats the purpose of a tablet, but it would be nice to still use it. Anyone have suggestions?
ktmm - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
