VTech InnoTab 2 Back Panel Replacement
    1. VTech InnoTab 2 Back Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Back Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Back Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Apply slight pressure and slide the button above the battery cabinet to the right to open.
      • Remove battery cabinet cover by sliding away from the center of device.
      • This device requires 4AA batteries to function without the AC adaptor.
    1. VTech InnoTab 2 Back Panel Replacement, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Back Panel Replacement, Back Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Back Panel Replacement, Back Panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove all nine plastic caps from the back of the device using the plastic opening tool.
      • These covers are made of hard plastic so they may be difficult to remove.
    2. VTech InnoTab 2 Back Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Back Panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Back Panel Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
      • Be careful not to apply excessive force.
      • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
    3. VTech InnoTab 2 Back Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech InnoTab 2 Back Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
      • Do not use excessive force while removing the screws to prevent damaging the plastic case.
    4. VTech InnoTab 2 Back Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech InnoTab 2 Back Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the plastic opening tool, detach the back plate from the front piece.
      • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
      • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
Roberto Valdes
crwdns2935283:010/18/17crwdne2935283:0
302 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G85, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S1-G85, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S1G85
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 93
crwdns2942667:0crwdne2942667:0 880
