VTech CS6719-2 Charging Wire Repair
  1. VTech CS6719-2 Charging Wire Repair, Base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech CS6719-2 Charging Wire Repair, Base: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
  2. VTech CS6719-2 Charging Wire Repair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to separate the bottom from the top.
    • There are two clips, located top and bottom, that you have to compress with the spudger.
  3. VTech CS6719-2 Charging Wire Repair, Charging Wire: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
  4. VTech CS6719-2 Charging Wire Repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Refer to How to Solder and Desolder connections How To Solder and Desolder Connections
    • Note: Ensure the old solder joint is removed.
    • Caution: Soldering iron and joint will become very hot.
  5. VTech CS6719-2 Charging Wire Repair: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat up solder joint on the base unit where the charging wires are connected.
  6. VTech CS6719-2 Charging Wire Repair: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take a wire of solder and apply to joint on board to remove the extra solder.
    • Remove charging wire connection.
Josh Showalter
crwdns2935283:002/08/16crwdne2935283:0
442 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-4, Baechle Spring 2016 crwdns2935289:0IUPUI, Team 1-4, Baechle Spring 2016crwdne2935289:0
IUPUI-BAECHLE-S16S1G4
crwdns2942667:0crwdne2942667:0 1,460
