VTech CS6719-2 Charging Wire Repair
crwdns2869540:0crwdne2869540:0: 1,9 тыс.
2
21
84
1 928
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:015crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
During this guide, the base will need to be disassembled and then desolder the charging wire connections.
    1. VTech CS6719-2 Charging Wire Repair, Base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech CS6719-2 Charging Wire Repair, Base: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
    2. VTech CS6719-2 Charging Wire Repair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the spudger to separate the bottom from the top.
      • There are two clips, located top and bottom, that you have to compress with the spudger.
    1. VTech CS6719-2 Charging Wire Repair, Charging Wire: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
    2. VTech CS6719-2 Charging Wire Repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Refer to How to Solder and Desolder connections How To Solder and Desolder Connections
      • Note: Ensure the old solder joint is removed.
      • Caution: Soldering iron and joint will become very hot.
    3. VTech CS6719-2 Charging Wire Repair: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Heat up solder joint on the base unit where the charging wires are connected.
    4. VTech CS6719-2 Charging Wire Repair: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Take a wire of solder and apply to joint on board to remove the extra solder.
      • Remove charging wire connection.
Josh Showalter
crwdns2935283:002/08/16crwdne2935283:0
442 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-4, Baechle Spring 2016 crwdns2935289:0IUPUI, Team 1-4, Baechle Spring 2016crwdne2935289:0
IUPUI-BAECHLE-S16S1G4
crwdns2935297:096crwdne2935297:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 84
crwdns2959996:0crwdne2959996:0 1,928
