This guide will show you how replace a faulty mode switch if your device does not properly switch modes.
To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
Remove the battery door.
Take out the batteries.
Remove the rear panel screws using a Phillips #2 screwdriver.
Two 21.6mm (Long)
One 9.8mm (Short)
Five 13.8mm (Medium)
Gently pull up on the rear panel.
Rest the laptop open on the table.
Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
Using a Phillips #0 screwdriver, remove the seven screws securing the mode switch assembly to the device.
Five 7.3mm
Two 6.0mm
Once the screws have been removed, the mode switch assembly can be removed easily.
You need this spring to find a matching replacement if it is in anyway damaged.
