VTech Baby's Learning Laptop LEDs Replacement
  1. VTech Baby's Learning Laptop LEDs Replacement, LEDs: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop LEDs Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop LEDs Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech Baby's Learning Laptop LEDs Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, unscrew the six 7.3mm screws holding the screen together.
  4. VTech Baby's Learning Laptop LEDs Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech Baby's Learning Laptop LEDs Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech Baby's Learning Laptop LEDs Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the lid closed, position the device such that the handle is pointing towards you.
    • Using your fingers, gently pry open the cover from the hinge.
    • Attempting to remove the cover while the lid is still open may cause unwanted damage to the device.
  5. VTech Baby's Learning Laptop LEDs Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 6.0mm screws from the LED array using a Phillips #0 screwdriver.
  6. VTech Baby's Learning Laptop LEDs Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pickup the array by the opening in the center of the board.
    • Remove the faulty LEDs by desoldering each from the board. You may refer to this soldering guide if necessary.
    • Movement of the array will be limited as it is still attached to the main device board.
Christopher Kourmoulakis
crwdns2935283:009/03/15crwdne2935283:0
385 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-2, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 12-2, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S12G2
crwdns2942667:0crwdne2942667:0 1,185
