crwdns2959928:0crwdne2959928:0 ↓Has the sound for your device suddenly stopped working? Unable to adjust the volume? This guide may be the solution to your problem.
To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
Remove the battery door.
Take out the batteries.
Remove the rear panel screws using a Phillips #2 screwdriver.
Two 21.6mm (Long)
One 9.8mm (Short)
Five 13.8mm (Medium)
Gently pull up on the rear panel.
Rest the laptop open on the table.
Flip your device so the bottom panel is facing up.
Use a Phillips #2 screwdriver to remove the two 7.7mm screws on the volume switch.
