crwdns2959928:0crwdne2959928:0 ↓Does your device not respond when buttons are pressed? Do only a few buttons seem to function correctly? This guide will walk through the steps required to replace the buttons.
To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
Remove the battery door.
Take out the batteries.
Remove the rear panel screws using a Phillips #2 screwdriver.
Two 21.6mm (Long)
One 9.8mm (Short)
Five 13.8mm (Medium)
Gently pull up on the rear panel.
Rest the laptop open on the table.
Using a Phillips #0 screwdriver remove the two 6.0mm screws.
Lift up on the board and set it aside.
Remove each button and button contact.
