VIT P2402 Laptop Disassembly
  1. VIT P2402 Laptop Disassembly, Removing the Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VIT P2402 Laptop Disassembly, Removing the Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VIT P2402 Laptop Disassembly, Removing the Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the laptop upside down, with the battery up.
    • Slide the security latch to the left.
    • Slide the security latch to the right with force
    • The second security latch ejects the battery from its place. Remove it.
  2. VIT P2402 Laptop Disassembly, Remove the service panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VIT P2402 Laptop Disassembly, Remove the service panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VIT P2402 Laptop Disassembly, Remove the service panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six Phillips 00 screws that hold the service panel.
    • Remove the panel and clean it with a brush. Take special care in the slits and fan area.
    • Use a blower to remove dust from the fan. You must avoid turning this with pliers. The flow should be opposite to normal the normal circulation when the laptop is turned on. Use a small brush to loosen the dust.
  3. VIT P2402 Laptop Disassembly, Remove the memory and the hard drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VIT P2402 Laptop Disassembly, Remove the memory and the hard drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VIT P2402 Laptop Disassembly, Remove the memory and the hard drive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull both retention hooks until the memory tilts.
    • Remove the memory
    • Pull the hard drive case so that you can move it to the left
    • Here we can see the SATA data and power connector.
  4. VIT P2402 Laptop Disassembly, Remove the screws of the interior chassis: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 8 Phillips 00 screws from the inside chasis
  5. VIT P2402 Laptop Disassembly, Remove the keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VIT P2402 Laptop Disassembly, Remove the keyboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop right-side up and use the tabs to remove the upper part of the the keyboard
    • Pull it slightly above the keyboard, enough to free the pegs from the inner part.
    • Tilt the keyboard from the inner part first. Free the ribbon cable from its two retainers.
  6. VIT P2402 Laptop Disassembly, Remove the two ribbon cables: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VIT P2402 Laptop Disassembly, Remove the two ribbon cables: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VIT P2402 Laptop Disassembly, Remove the two ribbon cables: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ribbon cable that connects the motherboard to the touchpad
    • Lift the plastic retainer gently
    • Remove the ribbon cable from the upper part the same way. This connects to the power button.
  7. VIT P2402 Laptop Disassembly, Remove the screws and take out the DVD drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VIT P2402 Laptop Disassembly, Remove the screws and take out the DVD drive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VIT P2402 Laptop Disassembly, Remove the screws and take out the DVD drive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two Phillips 00 screws
    • Remove the internal DVD unit
    • Remove the upper part of the chasis. Remove the powder from the other side.
  8. VIT P2402 Laptop Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VIT P2402 Laptop Disassembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Proceed to clean the dust. You can remove the watch battery if necessary: model CR2032.
    • Use a brush to clean the fan blades if possible.
  9. VIT P2402 Laptop Disassembly, Charging Pin: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VIT P2402 Laptop Disassembly, Charging Pin: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here we see the epoxy used to fix the charging pin, it can be used to prevent any contact.
    • Use an exacto knife to remove the excess epoxy.
    Buenos dias, quiero aumentar la memoria ram de este modelo de vit, me podrian orientar un poco acerca de cual podria colocarle y hasta cuanta ram podria aumentarla? Gracias. Deivis.mantilla6@gmail.com
    Deivis Mantilla - crwdns2934203:0crwdne2934203:0
    Saludos, segun recuerdo esta laptop usa memoria tipo DDR3. Potencialmente puede llegar a 8GB o incluso 16GB. Pero hay forma de asegurarse instalando una aplicación que indica el tipo de memoria. Me puede contactar por twitter o por otras RRSS si revisa mi perfil de iFixit para guiarlo con la aplicación.
    Marcos Mora -
    que chipset tiene la placa? para saber que procesadores soporta para upgrade.
    victor060818 - crwdns2934203:0crwdne2934203:0
    Saludos, chipset HM76.
    Con lo cual, sería compatible con la 2da y 3era generación, con socket FCPGA988. Esto según: https://vitsdata.blogspot.com/2018/01/eq...
    Marcos Mora -
    Excelente explicación muy detallada y buena gracias
    Pedro Gomez - crwdns2934203:0crwdne2934203:0
    hola no se si vea esto pero si lo hace me podria decir si en el chip de video trae discipador?,compre una de ese modelo y no lo trajo y se me apaga,quiero saber si es por eso muchas gracias
    alejandro30304674 - crwdns2934203:0crwdne2934203:0
Para volver a montar tu aparato, siga estas instrucciones en orden inverso.
crwdns2935229:016crwdne2935229:0
crwdns2934873:0crwdne2934873:0
es en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Marcos Mora
crwdns2935283:012/17/17crwdne2935283:0
3.840 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
crwdns2947412:068crwdne2947412:0
Saludos Marcos Saludos estas vit p2402 poseen en el circuito de encendido un componente SMD de numeración X315, podrias por favor ayudarme a identificar que cosa es y cual es su funcion, pues al parecer me esta presentando problemas y necesita ser reemplazado, pero eso no sale como transistor, no es un simple mosfet, no es un regulador termico, ni de carga,no es diodo, que cosa es? y sobre todo, en caso de no conseguirlo, con que se puede sustituir este componente.
Miguel Martinez Rodriguez - crwdns2934203:0crwdne2934203:0
Saludo Miguel.
Veo que en google no sale ese componente. Lo que hice con la laptop de la guía fue cambiar el pin de carga por otro haciendo un corte y tape negro. sin embargo, me puedes contactar si pinchas mi perfil de ifixit, verás mi redes sociales.
Marcos Mora -
hola me gustaria que me orienten, mi lapto vit p2402 no prende devido a que tuvo un corto circuito y se le quemo una fuente. la pieza dañada es i225al2v. la pregunta es puedo sustituir esa pieza y lograr de alguna manera que funcione con normalidad.
LARRYZ MOYANO - crwdns2934203:0crwdne2934203:0
Saludos. No tengo como ayudarte en eso ya que por ahora no tengo el conocimiento de electrónica y microsoldadura necesario.
Si se te ofrece otra cosa, puedes contactarme por mis RRSS que aparecen en mi perfil de ifixit.
Marcos Mora -
Amigo no sabes que modelo es el pin de carga para poder reemplazarlo… Gracias
jose escobar - crwdns2934203:0crwdne2934203:0
Es muy difícil responder a eso, esos pines no tiene códigos que uno pueda identificar para buscar. A veces lo nombran según el diámetro, medido en milímetros, pero varios modelos incompatibles coinciden en ese número.
Recomiendo es sacar el pin malo y llevarlo como muestra a diferentes tiendas y vendedores a ver quien te vende un reemplazo que coincida.
Cualquier cosa, me puedes contactar en mis RRSS de mi perfil de ifixit.
Marcos Mora -
Amigo te escribo porque mi laptop vit p2402 la misma est encendida trabajando un buen tiempo ,puede que una semana o 5 días y de un momento a otro esta se apaga y pasan 2 minutos y la enciendes y no reconoce el disco pero la dejas reposar 5 o 10 minutos y enciende y reconoce el disco y escapas de trabajar 3 o 4 horas más y en este período de tiempo se vuelve a apagar y así seguidamente y el error que da es error de disco pero no creo que sea el disco porque ya le cambiado 2 discos e incluso 1no de estos lo puse a trabajar en otra laptop y hoy en gia sigue trabajando ( que puedes orientar que sea este problema) y las memorias RAM son nuevas las cambie pensando que este era el problema, porque un amigo me lo sugirió.
Alex Yera Ortiz
ALEX YERA ORTIZ - crwdns2934203:0crwdne2934203:0
Saludos Alex, eso suena en parte a un problema térmico, has probado limpiar las aspas del ventilador? para una consulta más detallada puedes contactarme en mis RRSS que están en mi perfil de ifixit.
Marcos Mora -
Hola Marcos,
Un cordial saludo.
Tengo una VIT 3400-01 y quiero reemplazar la batería y el ventilador del procesador pero no sé cómo buscar las piezas.
Gracias de antemano.
Manuel Mauricio Naveda Santana - crwdns2934203:0crwdne2934203:0
si mal no recuerdo esa laptop usa una batería “rectangular, plana, interna” en lugar de las tradicionales que se extraen con facilidad. No es fácil de conseguir un reemplazo porque es casi obligatorio que te lo vendan como repuesto de otra (una laptop “donante”) que estén en peores condiciones y venden las partes como repuesto. Cualquier cosa, puedes contactarme a mis RRSS en mi perfil de ifixit.
Marcos Mora -
Buenas tardes, Amigo necesito el manual de dicha tarjeta madre para identificar siertas cosas en ella, Sabes donde encontrarla ya que no la e podido encontrar. Gracias
rmgarrid - crwdns2934203:0crwdne2934203:0
Saludos, he intentado conseguir el manual, pero no aparece. Lo único que no he intentado es ponerme en contacto con la empresa VIT. Podrías intentar eso. De resto, puedes contactarme en mis RRSS que están en mi perfil de ifixIT
Marcos Mora -
hola buenas noches Marcos, tengo una p2402 y quiero hacerle una ampliación de Ram, y queria saber si me guantaria un nodulo de 8 gs de ram o si seria mejor comprar dos de 4 una para cada solts?
Andrea Medina - crwdns2934203:0crwdne2934203:0
El máximo de RAM que soporta esta laptop depende del CPU, porque el chip controlador de memoria viene en él, tendrías que decirme cual es o investigar por tu cuenta. Sin embargo, también es posible que la placa base lo limite de alguna forma, por eso no me arriesgo a decir un “si” tajante. Necesariamente hay que probar 2 DIMM de 8GB cada uno para asegurarlo (yo tengo un par de esos que uso para trabajo, parar probar pues). Me puedes contactar a mi twitter que aparece en mi perfil de Ifixit.
Marcos Mora -
Hola, tengo una laptop Vit P2402, se le hundió el pin de carga, hay que sustituirlo por uno nuevo o hay alguna manera de llevarlo a su lugar?
Emilys - crwdns2934203:0crwdne2934203:0
Si el pin aún suministra corriente y no se apaga con pequeños movimientos, pues debería poderse arreglar así: se corta un taco de madera que empuje el pin en su lugar (ver paso 9) para que no se “se hunda”. Lo que yo hice con la laptop finalmente fue sustituir el pin por otro, pero es que el original estaba malo. (esto no aparece en la guia, fue después). Al nuevo pin le alargué el cable y queda “afuera” de la laptop, así no hay forma de que se hunda. Funciona muy bien.
Marcos Mora -
Muchas gracias por la información, puede desarmar y armar la laptop sin problemas y reparar el pin de carga.
Saludos
Jesus Alberto Mayorga - crwdns2934203:0crwdne2934203:0
Que bueno que pudiste, cualquier duda, puedes escribirme en twitter o instagram. En mi perfil de IFixIt salen.
Marcos Mora -
Hola Marcos, muy buena tu guía. Tengo un modelo igual, pero no me funciona la cámara, es como si estuviera desconectada. Tienes alguna idea de cuál es el conector de la cámara? Saludos
Emilio Acacio López - crwdns2934203:0crwdne2934203:0
Saludos, no puedo decir con seguridad, pero en el paso 5 hay una flex largo debajo del teclado, en la parte cercana a la pantalla, puede ser ese. Puedes contactarme en mis RRSS que aparecen en mi perfil de ifixit.
Marcos Mora -
Saludos… tengo una VIT P2402… con el cargador ella funciona bien pero cuando se va la energía eléctrica, o quiero trabajarla sin el regulador no funciona… Ya revisé la batería y está buena… Para saber si es algún componente en particular o es el Ping de carga…
Si me pueden orientar para ver si tiene solución o no esta falla…..
Gracias de antemano
Jorge Murillo - crwdns2934203:0crwdne2934203:0
Eso suena a problema con la tarjeta madre. Pero no puedo asegurarlo. Es posible que deje de funciona de una día para otro. Recomiendo hacer respaldos diarios con algún software automático y un disco externo.
Marcos Mora -
hola marcos, excelente manual. quiero felicitarte por tan buen material y por tomarte tu tiempo en responder las preguntas de todas las personas que por aca te contactan. el motivo del presente comentario aparte de saludarte, felicitarte y agradecerte es para que orientes con un problemilla con una laptop vit p2400, el problema es que no me quiere iniciar ningun window ya sea de 32 o 64 bits. todos los que instalo quedan en el logo. he probado con varios discos duros y he cambiado la memoria ram, pero si instalo algun sistema linux arranca sin problemas de hecho estoy usando ubuntu y trabaja sin problemas. gracias de antemano por cualquier recomendacion
Anthony Herrera - crwdns2934203:0crwdne2934203:0
Saludos. Eso suena a que la imagen que estás usando para instalar windows está mala, o el pendrive está malo. Descarga otra imagen ISO de Windows, o usa otro pendrive.
Marcos Mora -
Saludos… Me gustaría saber si el procesador de esta laptop es reemplazable. Tengo entendido que es rPGA y que puede ser cambiado por un i5 3210m. Quisiera saber si se puede cambiar o si está soldado
Ender Fuentes - crwdns2934203:0crwdne2934203:0
Los de segunda y 3era generación, por lo general, si, puedes cambiarlos. Destapar y revisar a ver si se puede sacar el CPU. Algunos si vienen soldados.
Marcos Mora -
Buenas tardes Marcos, tengo una Vit M2400, y el teclado ha empezado a dañarse es decir a dejar de marcar ciertas teclas, que se puede hacer en ese caso?
Belkis Bracho - crwdns2934203:0crwdne2934203:0
Saludos, en ese caso, cambiar el teclado por uno nuevo. Asegúrate de remover todos los tornillos necesarios y llevar el teclado viejo como muestra.
Marcos Mora -
Buenas me puedes orientar. Para ver si es posible aumentarle la cantidad de memoria dedicada al Video en la vit p2402 . Ya qe tiene muy poca.
thefatherdiego_21 - crwdns2934203:0crwdne2934203:0
Saludos, por lo general, eso requiere que aumentes la cantidad de memoria RAM principal (este modelo debe aguantar hasta 16GB).
El BIOS normalmente asigna más memoria de video automáticamente.
Si no, te metes en el BIOS y lo cambias de forma manual.
No puedo garantizar que esto funcione, debes probar.
Marcos Mora -
Hola amigo quisiera saber cómo le coloco a mi laptop vit las cintas de audio, del touchpa y la de encendido ya que no logro colocarlas
Yunier Rodríguez Alcolea - crwdns2934203:0crwdne2934203:0
Ya no tengo la laptop. Normalmente, eso implica colocar las cintas flex en los conectores del tamaño exacto.
Marcos Mora -
Bd, se le puede colocar una Ram de 8 GB de una sola pieza o deben ser 2 de 4 GB
andersonrafaelrodriguez - crwdns2934203:0crwdne2934203:0
No debe haber problemas en colocar una o incluso 2 tarjetas de 8GB de RAM.
Marcos Mora -
Hola Marcos tengo un problema con una Lapto P2402 que me dio pantalla azul en el sistema windows 10. y no pude recuperar el sistemma.
tratando de solucionar desconfigure parte de la bios y ahora en el boot no me senala el DD para montarle un sistema operativo, para arrancarla desde una unidad de USB.
Luis Cuello - crwdns2934203:0crwdne2934203:0
La mayoría de BIOS tienen una opción para "cargar valores óptimos" o predeterminados. busca esa opción e intenta de nuevo.
Marcos Mora -
Mi laptop se prende el bombillo de la batería, cambia de color azul a rojo; conecto el cargador y sigue cambiando de azul a rojo…
Leonardo Izarra - crwdns2934203:0crwdne2934203:0
Puede que la batería esté mala
Marcos Mora -
saludos , estoy buscando la bateria de la vit p2402 no sabes donde la consigo o de otra bateria que se le pueda adactar ya que esas estan es casas si tienes alguna información por favor indícame que puedo hacer gracias
jose luis castillo - crwdns2934203:0crwdne2934203:0
Saludos, siempre busca en MercadoLibre, Facebook Marketplace, tiendas locales
Marcos Mora -
Hola MARCO quisiera que me orientes yo estoy buscando una batería para la laptop p2402 si sabes donde puedo conseguirla o si sabes también de si se le puede adaptar otra por favor avísame si tienes alguna información
Hola marco no contestaste mi pregunta por si tienes conocimientos dr que si hay otras baterías qie le hagan a la vitp o donde puedo encontrar una de vitp porfa avisame o si tu puedes conseguirla gracias
Buenos noches me podrían decir dónde puedo comprar el pin de carga de la PC VIT P2402?
Gracias
kevin isaza - crwdns2934203:0crwdne2934203:0
Mercadolibre, Facebook Marketplace, puedes visitar tienda locales de reparación de computadoras y levar la muestra
Marcos Mora -
Hermano, tengo un problema de carga que se refleja en la parálisis del teclado, la pantalla y por supuesto en el arranque de la Vit 2402 laptop, puedes indicarme las incidencias del mal uso de la carga de la bateria… Hay un componente que se interrumpe y no permite que abra el sistema operativo,por ende el teclado, la pantalla, el tactil, la cáma, ni el audio, demas de los puertos USB, de monitor externo, Lan, ect… …¿qué puedo hacer ? ezequieljosé… mi e-mail.. ezequiel 748@gmail.com
ezequielj - crwdns2934203:0crwdne2934203:0
Habría que hacer algunas pruebas para llegar a una conclusión. En primer lugar, funciona correctamente sin batería? Porque la batería es la principal sospechosa.
Marcos Mora -
Buenas tardes amigos, necesito si alguien tiene un backup de la bios que sea hex. por favor para que me ayuden, gracias. mi email lineagerhdz@gmail.com
carlos - crwdns2934203:0crwdne2934203:0
Saludos, sería bueno, pero nunca he hecho un backup de BIOS. Si tienes algún tutorial o video que lo explique, con gusto.
Marcos Mora -
Buenas alguien aqui que venda la pantalla de la p2402
Genesis - crwdns2934203:0crwdne2934203:0
Recomiendo ir y preguntar directamente en tiendas
Marcos Mora -
Buenas se puede remplazar el fan cooler de una laptop vip p2402 se le podria adaptar otro?
luisebalza60 - crwdns2934203:0crwdne2934203:0
Lo mejor es sacar el original y tomar fotos, con eso, se puede buscar un reemplazo, cuyas fotos coincidan. En general, llevar el fan cooler a las tiendas como muestra y pedir que comparen con la mercancía que tienen
Marcos Mora -
Hola amigo tengo una vit 2402 y tengo un problema cada 30 minutos se apaga sola así este conectada ya le hice mantenimiento y le cambie la pasta térmica y aún sigue el problema, que puede ser ?
kleyderman ponce - crwdns2934203:0crwdne2934203:0
Es posible que no tenga buen contacto entre el disipador de metal y el CPU. revisa si tienes que ajustar esa parte, incluso, a vece toca hacer modificaciones para mejorar el contacto. La alternativa es revisar si el ventilador realmente funciona.
Marcos Mora -
saludos, por favor podria indicarme que marca o fabricante y modelo es la tarjeta madre de la laptop vit p2402?
Vicente García Flores - crwdns2934203:0crwdne2934203:0
Saludos, lo más probable es que sea una tarjeta hecha en china por encargo, sin marca. Usualmente foxconn, pero los modelos así, tienden a ser únicos. Ya no tengo la laptop, no puedo verificar.
Marcos Mora -
buenas amigo crees que me puedas ayudar tengo una vit p2423 y quisiera saber como desarmarla que quisiera saber como quitar el lector de discos y colocarle un adactador para disco duros
deivid benitez - crwdns2934203:0crwdne2934203:0
Debes revisar cual tornillo mantiene la unidad de DVD pegada al case, basta con sacar ese y luego sacar la unidad. Revisa el paso 7 de esta guía.
Marcos Mora -
Mi laptop vit p2402 arranca pero no da video soluciones por favor
Launer Robles Elias - crwdns2934203:0crwdne2934203:0
Puede pantalla mala (probar un monitor externo para descartar esta parte. Puede ser RAM mala. Puede ser tarjeta madre mala.
Pueden ser varia cosas, pero sin verla y hacer pruebas no sabría decirte.
Marcos Mora -
el teclado queda como sujetado del medio
luis - crwdns2934203:0crwdne2934203:0
Los teclados de laptop por lo general vienen atornillados por debajo, desarmar y desatornillar esos primero.
Marcos Mora -
Hola. Tengo una laptop Vit p2402 que ya le cambié la pasta térmica porque se calentaba y se apagaba, pero sigo con el mismo problema trabajo un ratico y se apagaba, ya ni siquiera enciende.
Mi pregunta es hay que cambiar el micro procesador ? .. o qué puedo hacer.
José Andrés Oliva Meneses - crwdns2934203:0crwdne2934203:0
A veces es el pin de carga que medio se mueve y se apaga.
Pero, puede seguir siendo temperatura, usa "Core Temp" para medir eso.
Es posible que no exista buen contacto entre el disipador y el CPU. En cuyo caso hay que hacer alguna modificación.
También puede ser la tarjeta madre, la memoria RAM, incluso el disco. Hay que revisar.
Marcos Mora -
estoy en argentina, tendran el numero de partes del pin de carga??
Juan Carvajal - crwdns2934203:0crwdne2934203:0
Saludos. No tengo la laptop ni los números. Para buscar repuestos, lo mejor es llevar la muestra a las tiendas y preguntar en varias.
Marcos Mora -
Buenas noches amigo tengo una vit p2402 prende y al iniciar la carga de windows 10 se apaga y se reinicia
Alexis - crwdns2934203:0crwdne2934203:0
Tengo una laptop vit modelo P2402 al conectar en cargador enciende el power y queda encendido no enciende ningún leds me puedes ayudar con esa falla
José antonio - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 182
crwdns2942667:0crwdne2942667:0 24,486
