VEX V5 11w smart motor Un-seizing
  1. VEX V5 11w smart motor Un-seizing, remove top case and gear cartridge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • use a Small Phillips head screwdriver to remove the top case.
    • simply pull the cartridge out of the motor.
    • NOTE: my motor had no case when I got it so I only had the attached PDF for images.
  2. VEX V5 11w smart motor Un-seizing, remove main case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VEX V5 11w smart motor Un-seizing, remove main case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VEX V5 11w smart motor Un-seizing, remove main case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4 screws holding the top case on the motor.
    • Once the screws are removed you can pull the 2 pieces apart.
  3. VEX V5 11w smart motor Un-seizing, remove bottom gear cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VEX V5 11w smart motor Un-seizing, remove bottom gear cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VEX V5 11w smart motor Un-seizing, remove bottom gear cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2 Phillips head screws holding the bottom case on.
    • Pull the bottom case off.
  4. VEX V5 11w smart motor Un-seizing, remove center gear: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VEX V5 11w smart motor Un-seizing, remove center gear: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers, a small flathead screwdriver, or a spudger to remove the center gear.
  5. VEX V5 11w smart motor Un-seizing, tap and twist the motor shaft: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VEX V5 11w smart motor Un-seizing, tap and twist the motor shaft: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VEX V5 11w smart motor Un-seizing, tap and twist the motor shaft: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 1. Tap the small metal gear and metal shaft on the other side of the motor.
    • 2. Grip the metal gear with pliers and twist 1 full revolution or until the motor spins freely by hand.
crwdns2935103:0crwdne2935103:0
Austin Walter
crwdns2935283:001/16/23crwdne2935283:0
1,239 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 187
