VENSTAR Taco Logic Board Replacement Replacement
    1. VENSTAR Taco Logic Board Replacement Replacement, VENSTAR Taco Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VENSTAR Taco Logic Board Replacement Replacement, VENSTAR Taco Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VENSTAR Taco Logic Board Replacement Replacement, VENSTAR Taco Disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
      • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
    2. VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Repeat the previous step on the opposite side to remove the other outer casing.
    3. VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      Phillips #0 Screwdriver
      $5.49
      • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
      • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
    4. VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
    5. VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
    1. VENSTAR Taco Logic Board Replacement Replacement, Logic Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the rubber covering from the buttons.
    2. VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the black fabric covering the logic board.
    3. VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Move the battery out of the way of the connector.
    4. VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Undo the connector of the flat white ribbon between the switches and the logic board.
    5. VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Undo the two black 3mm screws on the logic board using the PH0 screwdriver.
    6. VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VENSTAR Taco Logic Board Replacement Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently pull out the logic board.
      • Note that the battery and the logic board are connected and must be removed together.
Kaylee Simms
crwdns2935283:001/30/16crwdne2935283:0
310 crwdns2915208:0crwdne2915208:0
University of Kentucky Louisville, Team 1-3, Matravers Spring 2016 crwdns2935289:0University of Kentucky Louisville, Team 1-3, Matravers Spring 2016crwdne2935289:0
LOUISVILLE-MATRAVERS-S16S1G3
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 643
