Using Needlework and Crochet to Patch a Hole in Knitwear
  1. Using Needlework and Crochet to Patch a Hole in Knitwear, Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear, Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear, Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Thread your desired yarn color through the needle.
    • In the row next to the hole, insert your needle into the bottom-most stitch from the back to the front, pulling all the way through (Image 2).
    • Insert your needle into the V-shaped stitch above, going through both loops of the stitch (Image 3).
  2. Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your needle back into the bottom stitch (from Step 1), pulling all the way through.
    • The resulting stitch should look like a V-shape.
    • Cut your thread, making sure to leave enough yarn to cover the rest of the hole.
    • The amount of thread you cut should be about a few inches (3 to 5) more than the width of the hole.
  3. Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Re-thread your needle.
    • In the stitch above your starting stitch (from steps 1 and 2), insert your needle from back to front, pulling all the way through (Image 1).
    • Insert your needle into the V-shaped stitch above, going through both loops of the stitch (Image 2).
    • Insert your needle back into the stitch below, pulling all the way through.
    • Cut your thread (same length as the first cut).
    • This entire process is a repeat of steps 1-2.
  4. Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat steps 1-3 until you've reached the end of the hole.
  5. Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Switch to using your crochet hook.
    • In the next row, insert hook into bottom loop (Image 1).
    • Hook underneath the thread above (Image 2).
    • Pull the thread through the loop (Image 3).
    • You can pull on the thread to tighten the stitch.
  6. Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert hook through light pink yarn.
    • Hook dark pink yarn.
    • Pull through light pink yarn.
  7. Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert top light pink yarn through eye of needle.
  8. Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull threaded needle through dark pink yarn underneath.
  9. Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Thread yarn through edge of the damaged hole.
    • Needle light pink yarn through dark pink yard beneath.
  10. Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Thread the top-most strand of light pink yarn through the needle.
    • Stick the needle through the stitch right beside it and pull it through.
  11. Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the needle underneath the two stitches right above from the left, and pull the thread through.
    • Do the same, but starting from the left side.
    • The final result should look like a heart-shaped stitch.
  12. Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the dark pink thread, push the needle through the right side of the next two stitches underneath the new light pink stitches.
    • Repeat but starting from the left side.
  13. Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the needle is pulled through, it should create a V-shaped stitch just like the one above it.
    • Continue all the way down the height of the hole.
    • Tuck loose strands of yarn into the back.
  14. Using Needlework and Crochet to Patch a Hole in Knitwear: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When all the stitches are complete, tie off each loose strand in the back with a secure knot.
    • Trim off excess strands of yarn.
Holly
crwdns2935283:004/26/24crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
UC Davis, Team 3-2, Whithaus Spring 2024 crwdns2935289:0UC Davis, Team 3-2, Whithaus Spring 2024crwdne2935289:0
UCD-WHITHAUS-S24S3G2
crwdns2942667:0crwdne2942667:0 207
