Urbanears Stammen Speaker not working: repair guide
  1. Urbanears Stammen Speaker not working: repair guide, Speaker Dissassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Urbanears Stammen Speaker not working: repair guide, Speaker Dissassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a metal spudger or a dull bread knife with a large surface, pry open the side cover of the speaker that is attached to the body by sticky tape. Take you time, the adhesive is very strong. Be careful not to damage the wooden body of the speaker during prying.
  2. Urbanears Stammen Speaker not working: repair guide: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Urbanears Stammen Speaker not working: repair guide: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Urbanears Stammen Speaker not working: repair guide: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next, continue by removing the screws hidden under these 6 rubber feet. Use a spudger to remove the rubber feet. Use a large philips screw driver for the screws. Then, remove the bottom cover, but be mindful to first remove the internal power cable that is attached to the internal power supply of the speaker (marked in red, last image).
  3. Urbanears Stammen Speaker not working: repair guide: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Urbanears Stammen Speaker not working: repair guide: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 6 screws on the side of the speaker the loosen the lower side panel. The main board of the speaker is attached to the inside of this lower side panel (Marked in red, second image). The board is attached to other components with cables. Be mindful to unplug each cable carefully upon removing the side panel.
  4. Urbanears Stammen Speaker not working: repair guide: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Urbanears Stammen Speaker not working: repair guide: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The main board consists of 2 board seperarte boards stacked together. The lower larger board hosts the TPS54335A. The function is to reduce the incoming 18V to a lower voltage suitable for the main processing chips. Uncrew the top board carfully to make space. Beware to shield any plastic connectors from hot air upon replacing the TPS54335A.
After replacing the TPS54335A, re-assemble the speaker by following the steps in reversed order.
michaelboot
crwdns2935283:008/13/12crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 161
