crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Unifi Dream Machinecrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Unifi Dream Machine Teardown, Remove Top Dome Cap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Spudger
    $3.99
    • Using a spudger, gently pry off the top dome cap.
  2. Unifi Dream Machine Teardown, Remove Wifi Antenna: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Unifi Dream Machine Teardown, Remove Wifi Antenna: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small PZ0 Philips Screwdriver Bit, remove the 3 screws.
    • Lift the WiFi antenna and remove the remaining screw
  3. Unifi Dream Machine Teardown, Remove Plastic Ring Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove these 4 screws
  4. Unifi Dream Machine Teardown, Pop Off Plastic Ring: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Unifi Dream Machine Teardown, Pop Off Plastic Ring: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    iFixit Opening Tool
    $1.99
    • Insert the iFixit Opening Tool under the ring lift and pop off the white plastic ring
    • Remove the ring
  5. Unifi Dream Machine Teardown, Remove Rubber Pad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Unifi Dream Machine Teardown, Remove Rubber Pad: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the bottom rubber pad
    • Remove the 4 screws underneath the rubber pad using PH1 Philips Screwdriver Bit
  6. Unifi Dream Machine Teardown, Remove the Shell: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Unifi Dream Machine Teardown, Remove the Shell: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Unifi Dream Machine Teardown, Remove the Shell: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This is the hard part, be patient
    • The power supply pin clip and RF grounding wire are keeping the shell connected to the core
    • Using a spudger or pick, gently pry off the RF grounding wire tape.
    • Once the RF grounding wire tape is removed, slowly twist and pull to release the power supply pin clip
  7. Unifi Dream Machine Teardown, Remove the Power Input Connector: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew these two screws
  8. Unifi Dream Machine Teardown, Insert Power Connector: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you want to test the PSU, you can reconnect the power connector
  9. Unifi Dream Machine Teardown, Remove PSU (optional): crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Unifi Dream Machine Teardown, Remove PSU (optional): crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In my case, the power was making it to the board, but wasn't being to converted from AC input to DC output
    • You can see in the red circle that likely there appears to be some discoloration. My guess, with this tight design, it overheated
Eric Pardee
169 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 189
crwdns2942667:0crwdne2942667:0 570
