Uniden Guardian G955 Battery Replacement
  1. Uniden Guardian G955 Battery  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, remove four 6.1 mm screws from your monitor using a J1 Phillips head screwdriver.
  2. Uniden Guardian G955 Battery  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully, use a metal spudger to open the case starting from any corner.
    • Slowly slide the spudger along the inside edge of the case.
  3. Uniden Guardian G955 Battery  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden Guardian G955 Battery  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 6.1 mm screws from the black fastener using a screwdriver.
    • Remove the black fastener.
  4. Uniden Guardian G955 Battery  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden Guardian G955 Battery  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the head of the cable attached to the motherboard by pressing on the outer edge of the cable and sliding it out.
    Tryed to get the battery out but stuck down so how do I get it
    Teressa Dodson - crwdns2934203:0crwdne2934203:0
  5. Uniden Guardian G955 Battery  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden Guardian G955 Battery  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Halberd Spudger
    $2.99
    • Remove the battery from the case by sliding a halberd spudger below it. (note: the spudger shown is metal, to ensure proper safety, utilize a nylon or plastic spudger.)
Sundus Al Shibani
crwdns2935283:010/04/16crwdne2935283:0
180 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Nance Fall 2016 crwdns2935289:0USF Tampa, Team 1-1, Nance Fall 2016crwdne2935289:0
USFT-NANCE-F16S1G1
The instructions and illustrations are fine, but there is NO information on how to obtain a replacement battery. I have searched without any luck.
Ricaedo Garcia - crwdns2934203:0crwdne2934203:0
Hello, I sure hope I can get a answer on this, Ricaedo Garcia was you able to find a replacement battery for yours. I been searching for one and no luck. Thank you
Kathy -
I’m going to try using this battery: YK843553-Battery-for-UNIDEN-UBW2101C-Camera-UBWC21-1250mAh
I think it will work. The connector and voltage are the same.
George Scott - crwdns2934203:0crwdne2934203:0
George Scott: Did that battery work satisfactorily?
PhBob - - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,972
