Uniden Guardian G955 Battery Replacement
  1. Uniden Guardian G955 Battery  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, remove four 6.1 mm screws from your monitor using a J1 Phillips head screwdriver.
  2. Uniden Guardian G955 Battery  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully, use a metal spudger to open the case starting from any corner.
    • Slowly slide the spudger along the inside edge of the case.
  3. Uniden Guardian G955 Battery  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden Guardian G955 Battery  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 6.1 mm screws from the black fastener using a screwdriver.
    • Remove the black fastener.
  4. Uniden Guardian G955 Battery  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden Guardian G955 Battery  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the head of the cable attached to the motherboard by pressing on the outer edge of the cable and sliding it out.
  5. Uniden Guardian G955 Battery  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden Guardian G955 Battery  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Halberd Spudger
    $2.99
    • Remove the battery from the case by sliding a halberd spudger below it. (note: the spudger shown is metal, to ensure proper safety, utilize a nylon or plastic spudger.)
Sundus Al Shibani
crwdns2935283:010/04/16crwdne2935283:0
180 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Nance Fall 2016 crwdns2935289:0USF Tampa, Team 1-1, Nance Fall 2016crwdne2935289:0
USFT-NANCE-F16S1G1
The instructions and illustrations are fine, but there is NO information on how to obtain a replacement battery. I have searched without any luck.
Ricaedo Garcia - crwdns2934203:0crwdne2934203:0
Hello, I sure hope I can get a answer on this, Ricaedo Garcia was you able to find a replacement battery for yours. I been searching for one and no luck. Thank you
Kathy -
I’m going to try using this battery: YK843553-Battery-for-UNIDEN-UBW2101C-Camera-UBWC21-1250mAh
I think it will work. The connector and voltage are the same.
George Scott - crwdns2934203:0crwdne2934203:0
George Scott: Did that battery work satisfactorily?
PhBob - - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,092
