Uniden EXP 371 Handset Casing Replacement
  1. Uniden EXP 371 Handset Casing Replacement, Uniden EXP 371 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Uniden EXP 371 Handset Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden EXP 371 Handset Casing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. Uniden EXP 371 Handset Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden EXP 371 Handset Casing Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  4. Uniden EXP 371 Handset Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Uniden EXP 371 Handset Casing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Uniden EXP 371 Handset Casing Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
  5. Uniden EXP 371 Handset Casing Replacement, Handset Casing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You must remove the speakers in order to replace the front casing of the phone. Use the #1 philips screwdriver.
    • Once the phone is completely disassembled follow the steps in the reverse order using the new phone case to reassemble your phone.
Ethan DiTullio
crwdns2935283:010/17/14crwdne2935283:0
125 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-1, Duarte Fall 2014 crwdns2935289:0UMass Dartmouth, Team 2-1, Duarte Fall 2014crwdne2935289:0
UMASSD-DUARTE-F14S2G1
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 213
