Uniden EXP 371 Charging Contact Points Replacement
  1. Uniden EXP 371 Charging Contact Points Replacement, Charging Contact Points: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden EXP 371 Charging Contact Points Replacement, Charging Contact Points: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Your first step will be to remove the battery cover and the battery.
  2. Uniden EXP 371 Charging Contact Points Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The next step will be to remove the two screws from the rear of the phone case.
  3. Uniden EXP 371 Charging Contact Points Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After that you will need to pry the back of the case off of the front part of the case.
  4. Uniden EXP 371 Charging Contact Points Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden EXP 371 Charging Contact Points Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the rear cover there will be two more screws to remove that hold each of the charging contact points. Once those are removed you can replace them with the new ones.
    • When replacing the charging contacts, they only go on one way, but it is useful to note how the original ones were on.
    • Reverse these steps in order to reassemble your phone.
Eric Rodrigues
crwdns2935283:010/16/14crwdne2935283:0
343 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-1, Duarte Fall 2014 crwdns2935289:0UMass Dartmouth, Team 2-1, Duarte Fall 2014crwdne2935289:0
UMASSD-DUARTE-F14S2G1
crwdns2942667:0crwdne2942667:0 232
