Uniden D1685 front panel and keypad replacement
  1. Uniden D1685 front panel and keypad replacement, Front Panel and Keypad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the phone over with the back facing upwards.
  2. Uniden D1685 front panel and keypad replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press your thumb down on the top of the cover and push downwards.
  3. Uniden D1685 front panel and keypad replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once removed the battery will be connected by 2 wires.
    • Do not pull the red and black wires.
  4. Uniden D1685 front panel and keypad replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the small, grey connector that is connected to the phone to disconnect the battery pack.
  5. Uniden D1685 front panel and keypad replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden D1685 front panel and keypad replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3.175 mm screws with the small Phillips head (PH1) screwdriver on the bottom of the phone next to where the battery was removed.
  6. Uniden D1685 front panel and keypad replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden D1685 front panel and keypad replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once removed, use plastic opening tool to pull the back and front apart in 3 different locations; the bottom and both sides.
  7. Uniden D1685 front panel and keypad replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After splitting the phone there will be 2 wires that connect the phone's circuit board with the speaker on the back.
  8. Uniden D1685 front panel and keypad replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The circuit board (Large Green) is attached by 1 3.175mm screw in the top, left corner.
    • Remove this screw using a small Phillips head screwdriver (PH!) from the iFixit toolkit.
  9. Uniden D1685 front panel and keypad replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screw has been removed, the circuit board will be removable.
    • Gently remove the circuit board and place it on the back of the phone.
  10. Uniden D1685 front panel and keypad replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden D1685 front panel and keypad replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The keyboard will now be accessible. Remove the Bumper Pad (rubber pad behind actual keypad).
    • Remove the keypad.
  11. Uniden D1685 front panel and keypad replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden D1685 front panel and keypad replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Clean the pad with cleaning spray and/or a brush.
  12. Uniden D1685 front panel and keypad replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once cleaned, make sure to dry off all of the components entirely.
William Mullens
crwdns2935283:003/27/15crwdne2935283:0
215 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 1-4, Naidoo Spring 2015 crwdns2935289:0University of Alabama, Team 1-4, Naidoo Spring 2015crwdne2935289:0
UA-NAIDOO-S15S1G4
Did all of the above but I can’t get the center piece to work! I have no volume control and I can’t access anything like phone numbers, etc.
Honda Dude - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 382
