Uniden D1483-3BK Circuit Board/Screen Replacement
  1. Uniden D1483-3BK Circuit Board/Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the phone with dial keys facing downward.
  2. Uniden D1483-3BK Circuit Board/Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden D1483-3BK Circuit Board/Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery cover toward the bottom of the phone.
    • Lift and remove the back cover from the phone.
  3. Uniden D1483-3BK Circuit Board/Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from its compartment.
    • Pinch the end of cord where the battery is attached to the phone and pull up gently.
  4. Uniden D1483-3BK Circuit Board/Screen Replacement, Handset Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden D1483-3BK Circuit Board/Screen Replacement, Handset Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 9mm Phillips #1 screws in the battery compartment.
  5. Uniden D1483-3BK Circuit Board/Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Uniden D1483-3BK Circuit Board/Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Uniden D1483-3BK Circuit Board/Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to carefully separate the two halves of the case.
    • Slowly work around the entire case to fully separate the halves before pulling them apart.
    • Wires inside the case hold the two halves together, tearing these wires will lead to a need for additional repair.
  6. Uniden D1483-3BK Circuit Board/Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden D1483-3BK Circuit Board/Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
  7. Uniden D1483-3BK Circuit Board/Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden D1483-3BK Circuit Board/Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
    • Set the board in the lower half of the case.
  8. Uniden D1483-3BK Circuit Board/Screen Replacement, Circuit Board/Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the circuit board on the table with the screen facing down.
  9. Uniden D1483-3BK Circuit Board/Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the desoldering braid and soldering iron, remove the solder around the cable for the speaker.
    • When installing the new board, use the soldering iron and solder to reattach the speaker cables.
Arbitrary Name
crwdns2935283:001/28/15crwdne2935283:0
1.083 crwdns2915208:0crwdne2915208:0
Penn State, Team 1-8, Kaschak Winter 2015 crwdns2935289:0Penn State, Team 1-8, Kaschak Winter 2015crwdne2935289:0
PSU-KASCHAK-W15S1G8
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 388
