Unbranded UB-15MS10 Screen Replacement
  1. Unbranded UB-15MS10 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool to pry off the lid of the memory card compartment.
  2. Unbranded UB-15MS10 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 Screwdriver to unscrew the two 1.2mm screws within the compartment. This allows the device to be opened.
    Try adding other pictures that show the location of the screws. Maybe use the circle tool to outline them in an overhead view.
    Brian Wetherell - crwdns2934203:0crwdne2934203:0
  3. Unbranded UB-15MS10 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Unbranded UB-15MS10 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert opening tools to partially pry open the cover.
  4. Unbranded UB-15MS10 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
  5. Unbranded UB-15MS10 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tape that is holding the battery in place.
    If you add a few more pictures, the guide will flow better. The image in this step is a big jump from the last image and could potentially confuse readers.
  6. Unbranded UB-15MS10 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the five 1.2mm screws that connect the circuit board to the device.
  7. Unbranded UB-15MS10 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are three silver tabs around the internal components that connect it to the frame with screws. Unscrew these screws to remove the internal components.
  8. Unbranded UB-15MS10 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the internal components from the screen and place them into a replacement screen.
    How to lift the internal components from the screen?
    Alfred H. Schaefer - crwdns2934203:0crwdne2934203:0
To reassemble your device, follow instructions 1-7 in reverse order.
Evan Peterson
crwdns2935283:003/08/17crwdne2935283:0
320 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S5-G5, Botvin Spring 2017 crwdns2935289:0UMass Dartmouth, Team S5-G5, Botvin Spring 2017crwdne2935289:0
UMASSD-BOTVIN-S17S5G5
All the instruction are fine to follow except the last one, step 8. What tool to use to lift the internal components from the screen frame or where to start to lift without damage to the internal components?
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 2,022
