Unbranded UB-15MS10 Back Camera Replacement
  1. Unbranded UB-15MS10 Back Camera Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
  2. Unbranded UB-15MS10 Back Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4-mm #0 screws from the inside of the Micro SD compartment.
  3. Unbranded UB-15MS10 Back Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Unbranded UB-15MS10 Back Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
    • Inserting the picks directly under the Micro SD compartment was the easiest place to get started. It still requires some force.
  4. Unbranded UB-15MS10 Back Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
    • As the gaps open, slide the guitar picks along the sides to separate the panels.
  5. Unbranded UB-15MS10 Back Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
  6. Unbranded UB-15MS10 Back Camera Replacement, Back Camera: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the small piece of black tape.
  7. Unbranded UB-15MS10 Back Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black 4-mm #0 screw.
  8. Unbranded UB-15MS10 Back Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To finish removing the camera, disconnect the camera ribbon from the white ZIF connector on the motherboard.
    • There are two very small prongs on the side which need to be pushed towards the center of the connector to remove it.
Jordan Turk
crwdns2935283:009/21/15crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-1, Baechle Fall 2015 crwdns2935289:0IUPUI, Team 2-1, Baechle Fall 2015crwdne2935289:0
IUPUI-BAECHLE-F15S2G1
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 756
